Resolume is seeing OSC input but not letting me map it like MIDI
I'm using the default MIDI to OSC patch for Max for Live and I'm getting input into Resolume, but if I enter OSC mapping mode nothing creates a new control.
Re: Resolume is seeing OSC input but not letting me map it like MIDI
You actually don’t map OSC, It’s all pre-mapped for you. You just need to find out the syntax and value type by entering the mapping mode and clicking on the parameter you want to control. Then that’s what you need to send from your controller to control the parameter.
