.fla convertion
popesz
.fla convertion
Post by popesz »
Guys, could somebody tell me how should i convert .fla extentions to any of the usefull file types of resolume?could be the best .swf.
i was looking for it everywhere and no solution!!
thanks in advance
Danger
Post by Danger »
you need Macromedia Flash (http://www.macromedia.com) to "compile" to swf
continuity-B
Post by continuity-B »
Assuming you have Flash...
.fla are the working files for flash, the ones you monkey about with when you make or update a file.
.swf are the usable files you export from these in flash for the web or resolume. To get these open your .fla in Flash then (off top of my head might not be exactly right) goto file>export then when you get the save dialogue window make sure the filetype is set to .swf.
That's it.
popesz
Post by popesz »
Thanks guys, do not know how could not i find it, but now i am editing my own flashes:)
IQvisuals
Post by IQvisuals »
macromedia is so easy:):cool::)
