Akai apc 40 mk2 mapping
Hi, i'm intetesting how i can map resolume like on picture? I need to map 16 columns with clips, but akai have only 8 column buttons
- gpvillamil
Re: Akai apc 40 mk2 mapping
Put the second set of 8 columns on a different deck, and use the bank select buttons on the APC40 to switch between the decks?
https://resolume.com/support/en/decks
The Clips in each deck will have the same Button
Deck 1, Layer1,Clip1 = Button = Deck 2 , Layer1, Clip1
~Berlin~
~Berlin~
Already work with decks, but interesting is it possible to do something like on picture )
- gpvillamil
Not sure how the Shift button is mapped on the APC, but perhaps that would be possible. Press the button directly for columns 1-8, shift+button for 9-16.
It would be straightforward to build a Max patch to do this, especially now that Max 8 supports MIDI mapping.
You want something like this then ...
https://vimeo.com/43073087
Except for the APC40mk2 and Resolume 6?
