Hi I’m trying to change scenes in luminair from Resolume .
Resolume can see luminair in osc output .
I’ve made custom osc shortcuts trying things like
/command/next
/scene/1
/scene/2
Etc
As I’ve set the osc out put to go direct to luminair is this all I have to do ?
Can’t figure out what i’m Missing ?
Osc output to luminair?
Re: Osc output to luminair?
Works for me with Broadcast, IP address or selecting Luminair in the dropdown as long as I have the right Outgoing Port.
Are you on Mac or PC?
If on a PC, have you checked your firewall settings?
Also, are you sure you don't have another app with the same default Port 4567?
As a note, it should be /scenes/1 not /scene/1 but /command/next should work.
