Resolume 6, DMX, Artnet and Strip Controller
Rob Proscreens
Post by Rob Proscreens »
Hi, any advice appreciated on Artnet. (Resolume 6)
Trying to connect to an Artnet Led Strip controller. Controller says it is connected. Either via. broadcast or Controller ID and IP.
Resolume's and other Artnetometers all showing Resolume outputting DMX correctly. Artnetometer nodes showing controller.
DMX work shop showing all nodes. No activity indicated on Controller nodes.
Controller works with Madrix. (My client does not want to go anywhere near Madrix ;)
My question's are:
Is Madrix a different Artnet protocol?
Which version of Artnet does Resolume 6 use?
Is this version backwards compatible?
Has anyone encountered similar and found a solution?
Regards and TIA,
Rob Vary.
Re: Resolume 6, DMX, Artnet and Strip Controller
Are you outputting to the correct universe:subnet?
Resolume numbers them form 0 (which is the first one), your strip controller might number starting from 1.
Rob Proscreens
Yes, and just to test I have run outputs to different subnets and universes in sequential order.
Do you have both Resolume and your led controller on the same IP address range?
Menno
Post by Menno »
Does resolume correctly detect the nodes as well? They should show up in your right click menu on the lumiverse in the screen setup. If they dont show up you might need to change network adapters in the preferences.
