Hi all,
I have a project that contain 20x5 led screen
The width will be 5120 pixels, the height will be 1280 pixels
I'm already have 1070ti GPU Crad, so i will split the output across 3x DP outputs over (DP to DVI cable)
My question is:
What is the maximum resolution that Arena support for outputs?
I'm worried about the maximum resolution for Arena Software
Arena maximum resolution support
Re: Arena maximum resolution support
16384x16384 is the max resolution and 5120x1280 is 20% less pixels than 4K so you’ll be fine.
Thanks Oaktown for your reply,Oaktown wrote: Wed Jan 09, 2019 06:15 16384x16384 is the max resolution and 5120x1280 is 20% less pixels than 4K so you’ll be fine.
Do you think the DP to DVI cable will reduce the pixels?
DVI single link is 165 MHz, (max 1920x1200/60) however you use that bandwidth and DVI-DL (dual link) is 330 MHz (max 2560x1600/60). You need a special adapter and cables to push DL. DVI-DL will support up to 4K/30 but nothing larger.
Thank you again for your supportOaktown wrote: Thu Jan 10, 2019 15:21 DVI single link is 165 MHz, (max 1920x1200/60) however you use that bandwidth and DVI-DL (dual link) is 330 MHz (max 2560x1600/60). You need a special adapter and cables to push DL. DVI-DL will support up to 4K/30 but nothing larger.
