Resolume Failed to Initialize
trippyhippy
Post by trippyhippy »
I just downloaded Resolume and can't open it because it says failed to initialize. Here's what it says in the log. Pls help. Much love <3
Error from the logs:
INFO: Logging has started
INFO: Initialise JuceResapiApp
INFO: Initialise ResApi
INFO: Initializing Resapi
INFO: Created ParamCollection
INFO: Created TaskManager with 10 threads.
INFO: Created InputController
INFO: Created DeviceChangeDetector
INFO: Creating VideoFormatManager
INFO: Registering basic formats
INFO: Registered 4 formats
INFO: Created VideoFormatManager
INFO: Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
INFO: Trying to create DirectShow capture input device for: HP Wide Vision HD Camera (DirectShow_\\?\usb#vid_05c8&pid_03bc&mi_00#6&3903199&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_HP Wide Vision HD Camera)
INFO: Creating NDIVideoServerManager
INFO: Initializing NDI library
INFO: Successfully initialized NDI library
INFO: Created NDIVideoServerManager
INFO: Creating DisplayCollection
INFO: Created DisplayCollection
INFO: First time OpenGL usage, initializing extensions.
INFO: Registering window class.
INFO: Successfully registered window class.
ERROR: ra::Context::createOffscreenContext: Failed initializing WGL.
ERROR: Escaped from error in ra::ContextManager::initialize(27): Failed to create primary context.
ERROR: Failed initializing Resapi, Contexts are required for rendering.
INFO: Prepare for shutdown
INFO: Force Stop Recording
INFO: Setting up default composition.
INFO: Composition Prepare for Shutdown
INFO: Update Composition List
INFO: Enumerating Compositions0.00023 seconds
INFO: Install Source Preset preprocessor
INFO: Install Effect Preset preprocessor
INFO: Install Animation Preset preprocessor
INFO: Loading Animation presets
INFO: Initialise took: 0.98898 seconds
INFO: ***
INFO: Shutdown sequence started
INFO: Composition Shutdown
INFO: Stop renderer
INFO: Stop Server if running
INFO: Clean up renderer
INFO: Save Application and VideoEngine settings
INFO: Serialize application model
INFO: Create preferences file (config.xml)
INFO: Write preferences XML (config.xml)
Menno
Re: Resolume Failed to Initialize
Post by Menno »
The opengl driver could not be found. What GPU are you using and have you installed the latest drivers?
trippyhippy
Tried updating my drivers but got a Windows error (code 43). I restarted my computer and that fixed the issue. Thank you!
