Monitoring clip states with an iPad?
benasp
Post by benasp »
I try to control Resolume with an ipad.
I first tried TouchOS. The most important function for me is the state of clips. (Basically clip on : light on, clip off : light off). After some tests and research through the forum, I realized that this isn’t possible.
That’s why I am looking for an iPad midi controller app which is able to understand the 5 midi statues of a clip (or at least on / off), as an hardware controller can do.
Do you know if this kind of app exists?
If not, do you know of another way to control and monitor the state of a clip with an iPad?
Thanks !
Ben
