frame rate limit?
evan01624
frame rate limit?
Post by evan01624 »
I'm trying to get myself a 240hz projector for a show, just wondering is there a limit of frame rate in Arena? Am I able to play a 240fps video in arena?
thanks!
Re: frame rate limit?
When Vsync is enabled in the GPU settings, the max fps Resolume can do will be the slowest display you output to. so if you have a 60Hz monitor for the UI, and connect a 240Hz projector, Resolume will max at 60FPS.
If your control monitor is also 240Hz (or you disable Vsync) Resolume will render up to 240FPS (or what your GPU can do)
