Hello, I'm running Avenue 7.2.1 on a 2017 MacBook Pro.
My primary issue is that Resolume will not recognize nor play ANY NDI source. This includes NDI sources, from Reslomue itself, Madmapper, vdmx all of which are on the same computer. AND NDI inputs over an ethernet connection to another iMac that's running VDMX. However, all of the other softwares are able to receive and play Resolume NDI outputs, and outputs from the other softwares local or otherwise.
I'm pretty stumped, and have searched the internet for answer to no avail. Thank you in advance for your help.
NDI Source Is "Offline"
Re: NDI Source Is "Offline"
Check the NDI gotchas here https://resolume.com/support/en/NDI_inp ... di-gotchas
Sounds like NDI can't find the route to the servers.
Also check if you have anything specific set up in NDI Access Manager on any of the machines.
Thank you for the suggestion, that led me to updating the NDI tools and the driver itself. However, Resolume is only able to accept one NDI output at a time. I have three NDI outputs operating on my localized computer. Meaning I'm not connected to any router or wifi. Resolume is picking up the composition output or itself, the output of madmapper, and the output of the NDI Scan converter tool. However, I can only select one at a time. If I enable two, it will turn the other to "offline". I will continue to play with the NDI Access Manager Tool.Zoltán wrote: Fri Sep 11, 2020 07:33 Check the NDI gotchas here https://resolume.com/support/en/NDI_inp ... di-gotchas
