Suggestions for getting an oscilloscope into Resolume 7?
NickDrexler
Post by NickDrexler »
I'm new to Resolume and could use some help figuring out how to do this.
Re: Suggestions for getting an oscilloscope into Resolume 7?
What do you mean by oscilloscope? Are you referring to something like an audio waveform readout? There are a few plugins that can do this. I'd check out juice bar for those.
NickDrexler
Arvol wrote: Wed Sep 30, 2020 20:29 What do you mean by oscilloscope? Are you referring to something like an audio waveform readout? There are a few plugins that can do this. I'd check out juice bar for those.
Yes I'm looking to display the waveform of an audio track. In juicebar I only see pluggins that display the equalizer readout.
There's nothing built in that will do this. Thought there would be a plugin for this. I know a few ways to do this using ndi or spout if that's something that would work for you.
NickDrexler
Arvol wrote: Fri Oct 23, 2020 23:16 There's nothing built in that will do this. Thought there would be a plugin for this. I know a few ways to do this using ndi or spout if that's something that would work for you.
im surprised no built in pluggin. But i am up for trying out ndi or spout. how can i do it?
drxian
Post by drxian »
still no built in oscilliscope?
Audio In CHOP in Touchdesigner, Then use an OP Viewer TOP while selecting it's source to be the Audio In Chop, then connect the OP Viewer TOP to a Spout/Syphon Out TOP and then look for a Spout source in Resolume. Quickest and easiest way I can think of.
