can this be done in avenue
I have 4 layers
each layer is a series of 20 or so short video clips in a specific color to drive some FX panels
I have the clips set up, looped appropriately, and set to random autoplay for each layer. Think simple atmospheric kinda stuff.
How can I trigger a single layer for playback? I tried to bind (key 1= clear layer 1,2,3,4 play layer 1) but then I can't have (key 2 = clear layer 1,2,3,4 play layer 2) because the clear is already bound. I would like selecting a playback layer to override whatever is currently playing.. so you select red you get red.. you select blue you get blue.. etc.
Also I assume I need Arena in order to do triggering via something like Chamsys right? Is OSC an option to trigger? I was thinking about just putting a 4 button X keys down by the console so you can pick the color scheme that way (having the UI on screen really isnt an option).
https://imgur.com/NMraxoB
simple auto playback
Re: simple auto playback
I can think of a way using video router (on top layer) and bypass all the other (actuall content) layers.
and then map 1 button for the different layer routers and its good to go...
https://resolume.com/support/en/sources#routing
~Berlin~
~Berlin~
