Shortcuts overview not visible ra6
Filipsz
Post by Filipsz »
Hi, there is no shortcuts overview visible so I cant simply get info of them in usage
Any solution? Thanks
Shorcuts not visible
Re: Shortcuts overview not visible ra6
Looks like there is not enough vertical pixels on your display to show it.
Try moving the panel to the right edge of the UI.
Filipsz
Post by Filipsz »
Shure, working, my appologize, basic mistake.))
Thx
