issue with Alley and Alpha Channel codecs
jakemelon
Post by jakemelon »
I have couple animations saved in Quicktime with alpha (using GoPro CinceForm / RGB 16bit) but Alley is unable to read the files.
What QT codec has to be used (with Alpha channel) that Alley will let me convert to DXV?
btw I am using Davinci Resolve to assemble my frames into animations and CineForm is the only codec that supports QT Alpha export.
thanks
jake
Empyfree
Re: issue with Alley and Alpha Channel codecs
Post by Empyfree »
Prores 4444 will play nicely with an alpha channel.
