doepler midi pocket dial
stark_
Post by stark_ »
has anyone tested the doepfer midi pocket dial controller on resolume??? does it work fine??
it look great for effects... but will it work?
http://www.doepler.de :)
komart_
Post by komart_ »
yes it's great,it works,it rocks !!
jmode_
Post by jmode_ »
yep. quite good. only the space near the knobs is too small to write something.
but the pocket dial has the best knobs ever and is almost invincible.
i can recommend the midiman oxygen usb keyboard too - its light, cheap and is works great. :)
stark_
Post by stark_ »
i've never used midi with resolume*
still waiting for that dawm cable to come in the mail.
but i want to know what can you really control using the knobs or a keyboard device...
for example can i control the amount of effects applied, etc....(the number of tiles in the tile effect, the amount of alpha etc)
edwin
Post by edwin »
check the preferences in resolume and you will see that nearly everything can be controlled thru midi.
So alpha, effect intensity etc..can be controlled by using your midi devices...
