Wire: Convenient new node for tracking between two values with ease-in/ease-out (quad-in/quad-out, exp-in/exp-out)
webel
Post by webel »
Wire: 7.8.0
If there is already a built-in way of achieving this please advise.
I appreciate one can achieve the following using some Math/Logic gymnastics; but even if you do, the current apparent lack of sub-patching means you can't conveniently reuse the solution.
Resolume Arena/Avenue enable one to, for example, move between Transform values with bounce and soft end value transitions, with easy selection of some popular envelopes like quad-in/quad-out, exp-in/exp-out etc.
Wire feature request A: It would be very nice to be able to do this in Wire, driving between two values, and with the option of bounce, loop etc. Timeline can already be used for a basic linear ramp between a Start value or End value. It could perhaps be adapted for the case A (but I think it would be better to have a new node type).
Wire feature request B: It would also be nice to be able to track to any new value from a current value with built-in drive modes. You move towards (but don't necessarily reach) a new target value until a new target value is set.
Example: You want to drive a Transform coordinate to create random motion, but you don't want it to be jerky, you want it start moving to each new random target coordinate smoothly (like quad-in/quad-out).
If you just use, say Metronome > Random > Smooth, you still get jerky motion when the target value changes. The proposal here is for a dedicate node that has the option to move to a target value on a given timescale, but with a choice of transition styles (including the basic Smooth linear mode).
edwin
Re: Wire: Convenient new node for tracking between two values with ease-in/ease-out (quad-in/quad-out, exp-in/exp-out)
Post by edwin »
Try using the Curve node, it has all the curves build in that we offer in the Envelope editor of Arena.
Metronome->Random->Smooth->Curve
