Compositions disappeared
Max
Post by Max »
Dear Resolume-Team,
I finished my new live-show in the end of last year and saved it. Now I wanted to opened the project again and all compositions are just gone. Everything is gone. All my old compositions and the new one. The folder ist just empty. I did’t work with Resolume during the last month due to no gigs apparently and I also did not change any major things on my computer.
PLEASE let me know how to get the projects back!. They where very complex and not easy to rebuild.
Let me know how to solve the problem of compositions just disappearing.
Thanks you.
Best
Max
Re: Compositions disappeared
Onedrive can mess with the folder structure, relocating your documents folder. That has had me searching for stuff a few times on one of my windows machines.
If you try opening the composition from the Compositions menu - Recents, does it open then?
Max
Post by Max »
No. Sadly it just goes directly to the empty folder.
Also, can't find any other documents folder. Where did you find the files, when they where relocated?
For me, they got moved to C:\Users\MyUser\Onedrive\Documents
I think Dropbox can do a similar thing.
Max
Post by Max »
I found everything in my dropbox online. I had the Dropbox tool installed to my computer some day and unistalled it a couple of days later in the end of last year. So that tool reorganized the folders somehow and deleted everything afterward with the unistall process.
Thanks for the help. That was a life saver!
