Trigger the same clip multiple times?
MichelangeloCozzo
Post by MichelangeloCozzo »
Is there any way to trigger the same clip multiple times without restarting the clip? I have a video of an expanding ring mapped to a key on my MIDI controller. I want it to be set up so that I can hit that key three times in a row and it generates that clip three times and each iteration runs to completion instead of how it is right now where it restarts the clip every time it's triggered.
Re: Trigger the same clip multiple times?
Currently that would be 3 clips in 3 different layers and 3 midi shortcuts.
Or a Wire patch that would play a pre selected file
