The Wire EnvelopeFollower node tutorial patch with comparisons vs Smooth, Fallback, and none is excellent!
More like this please. Although some tutorial patches are dedicated to a node type, it helps to see it used vs other similar node types and/or without it.
EDIT: Curve tutorial patch also excellent. Comparison of curve mapping modes using bouncing ball. Good.
Wire: Envelope Follower tutorial patch with comparisons vs Smooth, Fallback, and none is good!
Darren Kelly (PLAYlogo), Webel IT Australia
