Column switching. audio proble
赵云飞
Post by 赵云飞 »
Whenever there is a lot of audio and video material, the column switching audio will disappear for 2-3 seconds. This doesn't happen every time. This kind of error is a random problem. This problem has existed since version 7.2.1. Project file (if required). I can provide.
my computer configuration
CPU: i9 10980xe
GPU: RTX 3090
RAM: 64GB
Storage: Nvme M.2 4TB
Hope it can help me, thanks!
Re: Column switching. audio proble
What kind of Video files are you using in your composition?
赵云飞
Post by 赵云飞 »
All film sources are in DXV3 format, Fps 25,
The resolution is:
A screen: 3648*1344
B screen: 2496*2112
C screen: 3072*1920
D screen: 3456*3456
The Arena composite file is: 9664*2304
赵云飞
Post by 赵云飞 »
Zoltán wrote: Wed Jul 13, 2022 11:17 What kind of Video files are you using in your composition?
The resolution is:
A screen: 3648*1344
B screen: 2496*2112
C screen: 3072*1920
D screen: 3456*3456
How is the disk utilization when triggering these columns?
赵云飞
Post by 赵云飞 »
The disks I used were SAMSUNG 2TB SSD M.2-port (NVMe protocol) 970 EVO Plus (MZ-V7S2T0B), but I don't think that's the problem. But I think I can test it out in a few days
Internal or external?
赵云飞
Post by 赵云飞 »
Zoltán wrote: Wed Jul 27, 2022 09:45 Internal or external?
Do you mean disk or external trigger fragment?
Yes, is the ssd internal or external?
赵云飞
Post by 赵云飞 »
SSD is internal, and the same problem has occurred on site recently. This problem is confusing and random. It occurs for about 2 seconds.
