remove a selection of empty clips
Acidvideo
Post by Acidvideo »
it would be really nice if it was possible to select a bunch of empty clips and remove them so the empty spaces between clips are all gone at once
Re: remove a selection of empty clips
right click on the column name above for clear options :)
Acidvideo
Post by Acidvideo »
is there an option to do this when i randomly select a bunch of empty clips in different layers and different colomns?
