Keyboard Shortcut Slider UI
I MIDI Map the scroll bar but I'd love to be able to send a keystroke to it as well. So if I keep "red" clips at a certain spot, I'd love to press "R" and have it send a value to jump the scroll bar to my "red" clips.
Re: Keyboard Shortcut Slider UI
hey there...I like the idea in general. But I would guess using a keystroke is much likely to inter-fer with your show when live editing values.
What about using colored buttons on for example a streamdeck or so to send specific midi values to scroll to the right place in your deck?
best wishes
The only place you would use a keystroke would be to rename a clip/text block. Something I don't do in "perform mode" everything else is float and int values and not keystrokes. Request still stands ;)
