Wire OSC triggers to Arena
Blusound
Post by Blusound »
Hello
I'm pretty new to Wire and my programming skills are basic.
I did a patch that trigger a column when a specific clip reaches the end. I saved the patch as a effect and i'd like to drag and drops the effect on several clips. The patch is working but the effect not. What I did wrong?
Leonardo
Re: Wire OSC triggers to Arena
Nothing. Resolume doesn't have Global Shortcuts or loopbacks, so you'll need a translator like Chatagine to take that message out of port 7001 and bring it back into port 7000 (defaults) to make this work.
Blusound
Post by Blusound »
Hi Arvol
the patch is working and listen to the OSC messages and trigger the column but if I save the patch and close Wire the effect applied to a clip is not working.
Again, You'll need a OSC loopback middleware to make this work. Resolume Arena/Avenue can not send OSC from itself to itself. You need to come out of Resolume (OSC) into another app like Chatagine or Touchdesigner and then send it back to Resolume.
Blusound
Post by Blusound »
Thank you Arval
now it's very clear!
