clip cutting
emx
clip cutting
Post by emx »
not a bug sorry, but i couldnt find a place to ask this in:
how do you guys cut bigger movies/clips into smaller ones? i know there is premiere or so, but it cant export multiple clips in 1 go. i imagined a small software where you can precisely set in and out points (with keyboard shortcuts too (arrows, shift-arrows), and exports all small clips in 1 go so i can leave my pc alone for that time, and get 47 small clips taken out of matrix 4 :D
edwin
Post by edwin »
Hi Emx,
maybe virtualdub can do the job.
It supports scripting as well, so if it's not in it you can script it (or find someone else to do that)
Edwin
emx
Post by emx »
thanks a lot dude!!! i ll try
levon
Post by levon »
there is also the batch assistant for virtualdub, i havent used it but im sure it would do what you want it to.
http://www.brightonart.org/VDubBatchAssistant.shtml
emx
Post by emx »
thanks Levon!!
emx
Post by emx »
dudes!
thanks a lot; Virtualdub is perfect for me!!! :)
i can make a render queue with Job Control...
thanks a lot again...
