Apple silicon frame sync displays together
Luisgoinsane
Post by Luisgoinsane »
Hi!!! I have issues putting 2 display outputs together with mac. I mean my led screen is way to large I have to split it into 2 nova sending cards with one being the right part and the other one the left part so I send the 2 4k outputs from my mac but when I put them side by side to make a complete screen both outputs run out of sync. This happens also in windows but its a quick fix with nvidia mosaic or surround displays but I haven’t found a similar option for mac. Any ideas?
Re: Apple silicon frame sync displays together
With Windows' you get the option using the Quadro architecture. Apple refuses to do business with nVidia so you won't get this option. Using an AJA Corvid 44 12G you could achieve this.
Luisgoinsane
Thanks for the info
