creating flash files
krash
Post by krash »
I know that most flash plays excellent in resolume, but I am curious to know if there are default settings (size, frame rate, export settings) that are best when making flash files from scratch for play in resolume???
any tips would be great - I would like to start making all of my own swf files (which I will of course post for download) and would like to have the best settings to begin with as I will create a template to work from.
Thx,
K.
levon
Post by levon »
if the files are going to be compleatly vector, then the resolution doesnt compleatly matter. as long as the ratio is 4:3, or 16:9. if the flash files will contain non vector footage, then its a matter of prefereance, some people use 320x240, other people use 800x600. and everything in between.
