Screen Tearing when scroll horizontal running picture
terry77764
Post by terry77764 »
Normal use of the output video will not occur, but as long as the horizontal moving marquee same frequency effect appears this problem
I also try to use timeline to slide my long picture The same problem will also occur
I want to know the nividia control panel best settings for arena
MSI GE76
GTX 3080
RAM 32GB
2 Output
1 4K & 1 HD
video console E2
Re: Screen Tearing when scroll horizontal running picture
Vsync ON?
terry77764
Zoltán wrote: Sun Nov 26, 2023 12:11Vsync ON?
Is it best to open it?
Are there any other settings that need to be turned on? Thank you.
Vsync should be on.
If that doesn't help, make a video of the tearing and share here, so we can see what you're looking at.
