Is there. Way to find where clips are located from the file browser?
You can find the actual file from the clip just by clicking preview of the clip.
Is there a way to do the reverse? Can you find where the clip is located from the file browser or any other area?
Find clips from file
Re: Find clips from file
Anyone? Anything?
not currently, no.
If you are up to reading some XML, you can open the composition file in a text editor, and search for the file name, then go up a few levels, for the clip layer and column, and another level up to find which deck it is in.
