1º. Chaos configuration separatly for every layer. This can set differents timing for every layer, for example: may put only background in botton layer using decks 1 to 4 changing at 5 min. and some annunces on middle layer using deck 5 changing at 30 sec. all whithout lose focus on the working deck.
2º. Set default overlay/mask for every channel or clip separatly instead of layer overlay/mask? Some clips need specific overlay and when no VJ is present (my case, i'm a DJ, no a VJ) and I put resolume in chaos, I need run to the PC to change overlay for some clips that not see fine. Example: some clips using alpha overlay, some others use luma or Add overlay. This may be useful for unnatended VJing....
3º. Some scripting format for chaos, useful for a programed session instead of random chaos.
Thanks for a great software!!!
