refresh capture driver list 2.4 beta
juLiE
Post by juLiE »
2.4 BETA CHANGE LOG COMMENTS:
Capture driver list can be refreshed to be able to access camera's that have been connected after having started Resolume....
my setup:
Operating System: xp, sp1
Processor: amd athlon
Videocard: nividia geforce4 mx
Video Capture Card: NONE
File type: NA
Codec: NA
i'm using dv-cam (sony pal dcr-hc90e) + firewire for live video feed and *sometimes* this new fix works for me at the beginning of using resolume, but is not consistent; tested turning dv-cam on/off, pause, repeat, without restarting pgm, and although status *always* changes from "no device found" to "device found", sometimes there is no live feed video image when dragged yet again to same or different channel (gray background appears).
[ however, it no longer crashes resolume - nice. :-) ]
when did it work? well, it was difficult to find a consistent pattern; sometimes clicking on different channels back and forth, to clearning layer 2, finally made the image appear when device was dragged in afterwards - yet these paths repeated did not always work again.
before posting here, i read past comments about this feature and it seems like resolume creators have no issue with "dv-cam + firewire" - yes? yet, some others favor video capture cards for live video feed, avoiding firewire for stated reasons.
...yet, i like "dv-cam + firewire"; is futher developement possible or has limitations...and you have better things to work on? ;-)
merci beaucoup-olah, juLiE
