OSC Output Arguments
Digital_Flodur
Post by Digital_Flodur »
Hi I am using Resolume 7.21.3 and trying to send an OSC message to Synesthesia directly.
I am successful in getting a simple Custon OSC message working IE /scenes/acidjelly
My Problem is I cant figure out how to add an argument "/scenes/acidjelly abstract"
What is the correct format for adding an argument to a custom OSC Output?
Re: OSC Output Arguments
Changing the argument type is not possible currently for OSC output.
If you'd add the data to the address part, You might be evaluate that in your receiver.
