4 displays problem
hyde
4 displays problem
Post by hyde »
Hi
I'm trying to use 2 video card with 2 outputs each ( sub d + video out ) .
First I extend the desktop to the four screen in windows display properties.
Next I launch Resolume.
I see my four displays in screen setup.
I enable :
- the first one for interface with display layer1 + layer2 +layer3 + fx
- the second one for preview matrix
- the third for layer1 + layer2
- the fourth for layer 3
This screen setup doesn't work.
When I disabled one display in screen setup everything is fine.
Does anybody have the same problem ?
PC setup :
Asus P4C800 E
Pentium 4 2.8 ghz
ram 2*512 mo
AGP video card radeon 9200SE 128 Mo ( sub d, dvi, video out )
PCI video card radeon 9250 128Mo ( sub d, dvi, video out )
Catalyst driver
[Edited on 20-10-2006 by hyde]
abletonator
Re: 4 displays problem
Post by abletonator »
fixed! problem solved by running in windowed mode, not the best, but still a solution!!!
HerrNieDa
Post by HerrNieDa »
i had problems with a 2 screen setup with 2 tv-outs...
problem was to set resolution from PAL to 640x480 or 800x600...
maybe this works for you too!?
