decks appearing white: can't read
garyliving
Post by garyliving »
Sometimes when I start up the program some decks(not all) only show a blank white preview- even tho the clips, images etc will still open. (they also appear white blank on the layers mixer...
why? what can i do other than reloading?
C3pO
Post by C3pO »
had that too,some clips appear blank...flash clips sometimes show only an icon,
You can move the in-point cursor a bit to the right,so resolume starts the clip from frame 1 instead of frame 0,normally you should see the first frame then...
