Why i still use Resolume 5
HerrNieDa
Post by HerrNieDa »
i work with Resolume and Visution Mapio
still having hard times using R6 or R7
here are my struggles:
- Audio FFT works different and will not stick to 0/100%, its always above 0%/under 100%
it makes some Workflows to blend/trigger Effects by FFT impossible.
I could do a Workaround with a Audio FFT in vvvv which sends me OSC for example - but i don't see why i should go this complicated path.
- Edge Detection (and maybe other similar effect) does not work in combination with effects which like "transform" the texture - it works with colorizing etc. but not with "deforming" effects - also not with Visution Mapio.
this has a huge impact on my style/workflow and also can't get a workaround - maybe in R7 with Wire or a fixed ffgl effect.
- sadly there is no support for Visution Mapio in R7 (not the fault of Resolume).
and this is also very very sad cause it still is a pain to map with advanced output and keystone effects, masks etc... simply not a good workflow compared with Mapio.
maybe any other suggestions/workarounds or hope to see "Features"/fixes like this in the future?
Re: Why i still use Resolume 5
HerrNieDa wrote: Sun Mar 30, 2025 21:29 - Audio FFT works different and will not stick to 0/100%, its always above 0%/under 100%
Envelopes are great for tweaking parameter response: https://resolume.com/support/en/paramet ... n#envelope
Mapio supports texture sharing input and output, so you could chain it into a Resolume7 workflow.
We can do discounted upgrades to v7 from v5, if you're interested, check your shop account or contact us on mail@resolume.com with your v5 serial.
How is the mapio workflow easier for you?
HerrNieDa
Post by HerrNieDa »
ok, maybe Envelopes can fix those situations. Still think its "sad" that the FFT works in another way - makes no sense for me in any Situation but okay.
i use Mapio in R5/R6 mainly as plugin.
I can drop it on any instance (Clip, Layer, Group and Composition) and still can do stuff like Soft Edge in the Advanced Output.
I have the mapped Output on the Preview and don't need an extra Screen if i would map in R6/R7 only
I can drop Effects on the mapped output - NOT possible in the Resolume Workflow
only mapping with built in Keystone Effects, Masks and Advanced Output is as i mentioned a real pain and very limited compared to a Workflow with Mapio.
so Resolume 7 is not an option for me expect for very very simple projects without mapping which happened to me 0 times the last 10 Years.
I would be happy with working FFGL Effects in R6
or a similar way for mapping in R7 like with Mapio (besides i run all my Machines on Win7 and my next Operating System i will use 24/7 will be a Linux Distro cause new OSX/Windows is dead to me)
SamMorris
Post by SamMorris »
Zoltán wrote: Mon Mar 31, 2025 18:21
Do you still upgrade discount to v7 from v5 now?
Yes, we have discounts for upgrades from older versions to v7
You can find your upgrade options in your account, clicking the Upgrade button next to your license.
mowgli
Post by mowgli »
I'm confused.
If 5 works the way you like, what's the problem?
Sjan Top
Post by Sjan Top »
HerrNieDa wrote: Sun Mar 30, 2025 21:29 i work with Resolume and Visution Mapio
I feel your pain in lossing the Mapio plugin. I had some sick setups using the Mapio to remap video's inside my composition. Having Wire gives some new freedom's, but Wiire can not do what Mapio added.
HerrNieDa
Post by HerrNieDa »
mowgli wrote: Thu Jul 10, 2025 20:56 I'm confused.
the "problem" is i can't use for example Groups and Tons of other new features which were added in R6 and R7 including Wire.
So i am basically stuck with my old Workflow which is ok for me, also i hate Win10/11 so i'm fine with it so far - but doing the same since years now and missing the new features is quiet sad.
guess if i will ever evolve it seems like it goes in Linux or Touch Designer direction - it's a dead path for me here :(
Can you share a setup you did with Mapio which you can't do in Arena 7?
HerrNieDa
Post by HerrNieDa »
Zoltán wrote: Mon Aug 04, 2025 14:16 Can you share a setup you did with Mapio which you can't do in Arena 7?
Mapio is used as a Effect so i can put if on a Clip, Layer or the Composition to map and combine it with Effects.
I mostly use it on Layer (or in Groups in R6)
It is simply not possible in R7 or R6 without Mapio cause the mapping is procecced and viewed after the Composition Effects.
This also means if i want to see a Preview from my Output i need an extra Screen.
also the Workflow is 5 times faster and more logic than with Advanced Output only.
I never have to precompose a Composition for mapping. If i got complex 3D Content with 100's of slices i can import svg's and use them... maybe there it makes sense prepairing.
for me these are key features and make the new Versions useless.
R6 would be nice if the Effects would work as they should which is not the Case.
Wire looks nice but i've never hat a practical use for it so far.
I just don't understand where the direction of developing is going and am sad about missing features.
(like the Auto Invert Freeframe effect from Resolume 2 - never saw similar effects after that sadly).
