Winamp to Resolume?
Ozz
Winamp to Resolume?
Post by Ozz »
I recently did a 15 hours gig and by the end of it I was looking for auto vj solutions...
I'd like to be able to import a Winamp source into Resolume but this doesn't work too well with the plugin FreeFrame/VIDEO_10 PatchBoxSend. In fact this FF stopped working altogether in the latest version of Resolume...
Is there a easy way to import Winamp? As a source maybe (if so how?)
Thanks in advance for answering.
Ozz
VJzoo
Post by VJzoo »
you could run a comp with winamp full screen and mix it in or use a live capture card and input into resolume.
Ozz
Thanks for answering
Post by Ozz »
Infortunatly I work with 1 comp only and my graphic card doesn't reckognize Winamp as a source. So I'm stuck with Patchbox - I finally got it to work in R.4.41... Wouldn't be so bad if I knew in advance which avs Resolume can play, most of them don't work.
I guess I'll have to delete every avs Resolume seems to have a problem with. Gonna be fun, about 600 files testing :(
Best Regards,
Ozz
