Oxygen 8 v2 Midi controller problems
LongWalkHome
Post by LongWalkHome »
Hallo there
Im using a m-audio Oxygen 8 V2 midi controller with resolume 2.3, and i dont seem to be able to assign severall of the buttons, All the dials and main keyboard keys have worked fine, but the play, forward, rewind etc buttons wont assign.
Can anyone give me some advice?
Thanks all
Manwell
Post by Manwell »
Resolume only accepts the midi continuous controller messages from sliders, knobs etc. and midi note messages from keyboard keys. Other messages from transport buttons etc. are not recognised. You might be able to configure your Oxygen 8 to send midi note messages from the buttons by assigning a different midi note to each button. Check the manual to see if this is possible. If it is you will have to access the keyboards menu to change the settings of the buttons and save a setup with the new settings. Use this setup for resolume and the others for any other software that does accept transport controls (music software like cubase, sonar , ableton etc.).
LongWalkHome
Thanks for the advice, ill see what i can do!
levon
Post by levon »
hey longwalkhome... just out of interest, are you associated with the band of the same name from Melbourne, Australia?
welcome to the board. :)
vjcharm
Re: Oxygen 8 v2 Midi controller problems
Post by vjcharm »
I have noticed the same thing but have yet to try to re assign them. It sure would be handy to free up some controllers!
