Jumping to scenes in flash files
Sepp
Post by Sepp »
Hi Everyone.
I was wondering how to use the resolume parameters to jump to difference scenes in a flash file. The manual says it can be done but I can't find anywhere that explains how to do it and can't work it out myself.
Any help would be much appreciated.
Thanks.
Jingle
Post by Jingle »
you'de better not use the scene function in flash. Every tutorial dissuade's it.
but if you wan't to use flash with resolume. you should understand actionscript (== it's a bit like C).
you can use the parameters to select witch frame or movieclip you are going to play in flash.
ask and i'll help you.
Sepp
Re: Jumping to scenes in flash files
Post by Sepp »
Yeah I realise I need to use actionscripting.
Is there a good tutorial anywhere that someone can point me to explaining the actionscripting - resolume control interworking?
I have been using 'on mouse over' to skip to new frames in a flash file, which works okay but can be confusing sometimes.
(yeah I know I posted the original question almost a year ago) :lol:
