How to Safely Uninstall Avenue (keeping Arena)
jsummer
Post by jsummer »
I have purchased Arena and would now like to safely uninstall the demo version of Avenue and all its associated files without impaction my Arena files/application in any way! I'm on a Mac running Sequoia 15.7.1.
Is there an uninstaller? If not, i can remove files manually if you could let me know the location, ie: Library folder and other items or hidden files in addition to the obvious Applications & Documents folders.
Re: How to Safely Uninstall Avenue (keeping Arena)
There is no uninstaller for mac.
If you have work in your Documents/Resolume Avenue folder, you can copy those files over to the Documents/Resolume Arena
Uninstalling Avenue would be deleting the Avenue application folder.
jsummer
Post by jsummer »
Ok. thanks for that. I did find more files in my Library/Application Support folder with mostly preview files.
jsummer
Post by jsummer »
in fact, it looks like Resolume Alley, Arena, Avenue all create Previews files (PNG and XML) for any and all clips i've ever imported. this adds up!
would it be safe to remove the png & xml files i no longer use? (will the app just regenerate any files it needs?)
jsummer wrote: Sat Dec 13, 2025 19:42 would it be safe to remove the png & xml files i no longer use? (will the app just regenerate any files it needs?)
Yes, on both
