please can someone advise on sensible clip lenghts..
most of my clips are a few seconds long but i would like to incorporate 5 minute long sections...
also i am rendering at 640x480 using the PICVideo M-JPEG 3 codec... IS THIS A GOOD/OR THE BEST OPTION?
thanks, johnwhy
						clip legths
It,s no problem to use 5 minute clips. The picvideo mjpeg codec is the best for resolume, do make sure you set it up correctly though, the default settings are not the best.
See our manual for details:
http://www.resolume.com/support/manual/index.html#mjpeg
