Switching between 2 mappings
I have a show with some roll drops, that I want slice to when they are down, but have a fullscreen slice for the rest of the set. I am just just a compostion at the moment, how can I make this work? Do I have to use groups and just control the mapping with the group opacity?
Re: Switching between 2 mappings
Have you tried Slice transforms yet?
https://resolume.com/support/en/transfo ... -transform
Yes but the only way I can make it work is manually disabling the fullscreen slice in the advanced menu. Maybe I’m missing something?
Here you can find a pretty good explainer about what you can do with the Slice transform, the cheat slices might be the ones to use for your case
