Audio output
Wildporridge
Audio output
Post by Wildporridge »
Hello I'm fairly new to Resolume. It's not quite what Resolume is intended for but I'm looking to do a live video and audio mix to live speech for a drama. Since Resolume has no support for outputting audo I had an off-the-wall idea I want to throw out:
I remember when phono audio signal is plugged into a tv it displays the signal as a video- would it be possible to record an audio signal as a video that way then play it back and feed it into a mixing desk (without video effects)?
I expect there'd be a lot of compression and distortion, but would it work?
ROdrigueZ
Post by ROdrigueZ »
I believe not because resolume does not render audio, so any way you try to input it you will have no output audio.
You'd have to sinch the audio and video manually...
Perhaps too computers One with resolume and another one with Virtual Dj or MixMeister, it is not that hard to prep the files and trigger them at the same time..
