hi....few questions
Maya
hi....few questions
Post by Maya »
Hello, Im just beginning to do VJing more intensive, so i bought new laptop,
dell inspiron 1720, with 4 gigs Of ram, core 2 duo 2,4 and graphic card NVidia Geforce8600
Im using XP, but my windows crashes every time when I start Resolume...On the windows firewall I made exception for the resolume, but i have still the problem.
Can you help me?
Next, Im quite new in VJing, but I know Adobe programs, and Im making my material,
what is the best way to reduce size of clips made in after effects and premier pro?
In terms of hardware, im using just laptop, but i need bit of your experience what size of the files are the best for good quality but still fast performance.
Thank you,
Maja
Maya
Re: hi....few questions
Post by Maya »
is there anybody who can advice me? at least if there someone with my graphic card, can you explain me how to adjust it, it could be a problem....But that new graphic card is so complicated :roll:
On old laptop I didnt have any problems.... :|
Maya
Post by Maya »
ok people, thank you, here we go, in the moment in which I click on the resolume icon, in the time of 2,3 seconds, windows screen turn to blue and it says:
a problem has be detected and windows has been shut down to prevent damage to your computer.
if this is the first time youve seen this stop error screen, restart zour computer. If thois screeen appears again, follow these steps:
Check to be shure you have adequuate disc space. If a driver is identified in this stop message, disable the driver or check with the manufacturer for win updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates, Disable BIOS memorz options such as caching or shedowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select advanced startuop options, and then select safe mode.
Technical information
stop: 0X 0000008E (0XC0000090, 0x b4b2dfee, 0xafdd4384, 0x00000000)
OEM02AFX.SYS ADRESS B4B2DFEE BASE AT B4B22000, DATE STAMP 45a4a816
beginning dump of physical memory
physical memory dump complete
contact your system administrator to technical support group for further assistance
I have gig at this weekend....so I was thinking to use arkaos or motion dive, but I like resolume, and in this moment I feel really bad...
plus my resolution of screen is 1920 by 1200 color quality 32 bits....
I didnt have p5roblems with other applications, and laptop run really fine...
nwonknu
Post by nwonknu »
First before opening Resolume, set your screen to 1280X768, 16bit
Instal codecs, especialy Flash, dont use quick time.
Use Indeo5.1, Cinepack or PicVideo MPJEG.
Haha and reinstal current version of Resoulme, download first 2.3, instal, than 2.41
Maya
Post by Maya »
It doesnt work....and for that resolution I will not be able to work on my other projects...
can someone explain how can I adjust this graphic card? If resolume needs so low resolution I will need profile for it..
yesterday it was working when I put default monitor on, instead of multiply monitors, so i tried to adjust the profile, and now it crashes again, and when I put default monitor it changes do multiply no matter what I choose... :(
nwonknu
Post by nwonknu »
Resolume will work on higher resolution, but 1280 is native.
Seems that you have a bigger problem there.
scoobasteve
Post by scoobasteve »
Same problem here.
Bought a Windows laptop especially for Resolume.
And now everytime I want to open Resolume I get the famous blue Windows screen.
What is up with that?!
Maya
Post by Maya »
peeeeople....we neeed help here..
i dont want to use arkaos....all other programs are shit...I dont have MAC for modul 8...
sssssssssssssssssssoooooooooosssssssssssssssssss :o
Have you tried the advice given in this thread: Set your screen bit depth to 16 bit?
VJ Brambi
Post by VJ Brambi »
I have been getting this "blue death" a lot and i figured up why. My problem was that I've installed the newest drivers for my graphic card (Intel) from Win Update.
Try to switch to your source drivers (the ones that came with your laptop) - if this doesn't help you, then I don't know any other way. Good luck!
P.S. Arkaos VJ is also good though! ;)
" Just my opinion.. "
