Resolume loads, but crashes when clip is loaded
phidippus
Post by phidippus »
I'm a newbie! Just installed Resolume 2.41 and running as trial version. I initialize the app and am able to set preferences and screen setup, but when I load a clip, the program freezes.
- Screen resolution is set to 1280x1024 at 16 bit depth
- input and output in Resolume is set to 320x240 / 16 bit.
Operating System: Windows XP SP3
Processor: Pentium 4 3.0 ghz
RAM; 1.25 GB
Videocard: ATI Radeon Mobile 9800 256 mb
File type: demo footage 1
Codec: ?
DirectX 9.0c
Thanks for the help!
Here's the boot log:
Logging started: Friday, 18 July 2008 - 00:37
start up 7/18/2008 12:37:58 AM
create my documents folder if not exists for current user 7/18/2008 12:37:58 AM
create application data folder if not exists 7/18/2008 12:37:58 AM
check direct x version 7/18/2008 12:37:58 AM
check if flash is installed and version 7/18/2008 12:38:00 AM
init: previewer 7/18/2008 12:38:03 AM
init: decks 7/18/2008 12:38:03 AM
init: file browser 7/18/2008 12:38:03 AM
init: fx 7/18/2008 12:38:03 AM
init: sources 7/18/2008 12:38:04 AM
init: preferences 7/18/2008 12:38:04 AM
load avaliable MidiInput devices 7/18/2008 12:38:04 AM
Init Midi Controller list 7/18/2008 12:38:04 AM
Init Midi Notes list 7/18/2008 12:38:04 AM
Init Key list 7/18/2008 12:38:04 AM
Init Audio Capture device list 7/18/2008 12:38:04 AM
Load settings 7/18/2008 12:38:04 AM
Set Midi Input devices 7/18/2008 12:38:05 AM
Init DMX 7/18/2008 12:38:05 AM
Save settings 7/18/2008 12:38:05 AM
gather preferences 7/18/2008 12:38:05 AM
gather channel keyboard shortcuts 7/18/2008 12:38:05 AM
save preferences and keyboard shortcut settings 7/18/2008 12:38:05 AM
gather midi shortcut settings 7/18/2008 12:38:05 AM
get midi channel/ layer shortcuts 7/18/2008 12:38:05 AM
copy midi channel/ layer shortcuts 7/18/2008 12:38:05 AM
copy midi controller shortcuts 7/18/2008 12:38:05 AM
get midi effect shortcuts 7/18/2008 12:38:05 AM
get midi channels 7/18/2008 12:38:05 AM
save midi shortcut settings 7/18/2008 12:38:06 AM
save dmx settings 7/18/2008 12:38:06 AM
init: shortcuts and midi 7/18/2008 12:38:06 AM
init: recording 7/18/2008 12:38:06 AM
init: audio fft 7/18/2008 12:38:06 AM
init: render 7/18/2008 12:38:07 AM
init: bpm 7/18/2008 12:38:07 AM
init: screensetup 7/18/2008 12:38:07 AM
firsttime get displays 7/18/2008 12:38:07 AM
firsttime copy display setups 7/18/2008 12:38:07 AM
finalize screen setup 7/18/2008 12:38:07 AM
destroy screens 7/18/2008 12:38:07 AM
create screens 7/18/2008 12:38:07 AM
search main dxdraw 7/18/2008 12:38:07 AM
set dxdraw resolumedraw 7/18/2008 12:38:07 AM
position mainscreen 7/18/2008 12:38:07 AM
check for dvdmax 7/18/2008 12:38:07 AM
set global settings for multi and single screen 7/18/2008 12:38:07 AM
initialize all screens 7/18/2008 12:38:07 AM
dualscreen is false 7/18/2008 12:38:07 AM
initialize dxdraw 7/18/2008 12:38:07 AM
--------------begin intialize-------------- 7/18/2008 12:38:07 AM
creating overlay if needed 7/18/2008 12:38:11 AM
create surfaces 7/18/2008 12:38:11 AM
width:320height:240 7/18/2008 12:38:11 AM
create vidnet object 7/18/2008 12:38:11 AM
create spectrum surfaces 7/18/2008 12:38:11 AM
create watermark surface 7/18/2008 12:38:11 AM
create system surfaces 7/18/2008 12:38:11 AM
create system preview surfaces 7/18/2008 12:38:11 AM
create directshow movies 7/18/2008 12:38:11 AM
create vfw movies 7/18/2008 12:38:11 AM
check quicktime and create movies 7/18/2008 12:38:11 AM
check for capture devices 7/18/2008 12:38:11 AM
create dibs for pictures 7/18/2008 12:38:11 AM
create picture objects 7/18/2008 12:38:11 AM
create picture dib objects 7/18/2008 12:38:11 AM
create plugins 7/18/2008 12:38:11 AM
create flash 7/18/2008 12:38:11 AM
again try dvdmax if not created and if supported 7/18/2008 12:38:11 AM
get bltcaps 7/18/2008 12:38:11 AM
--------------end intialize-------------- 7/18/2008 12:38:11 AM
assign additional screens to resolumedraw engine 7/18/2008 12:38:11 AM
position displays 7/18/2008 12:38:11 AM
set screen setups 7/18/2008 12:38:11 AM
start render engine 7/18/2008 12:38:11 AM
render engine started 7/18/2008 12:38:11 AM
init: load startup decks 7/18/2008 12:38:11 AM
applying screen setup 7/18/2008 12:38:29 AM
checking reg code 7/18/2008 12:38:29 AM
checking reg code success 7/18/2008 12:38:29 AM
close screen setup window 7/18/2008 12:38:29 AM
initialise screen setup 7/18/2008 12:38:29 AM
finalize screen setup 7/18/2008 12:38:29 AM
--------------begin finalize-------------- 7/18/2008 12:38:29 AM
deinit effectgenerators 7/18/2008 12:38:29 AM
destroy surfaces 7/18/2008 12:38:29 AM
destroy flash 7/18/2008 12:38:29 AM
destroy directshow movies 7/18/2008 12:38:29 AM
destroy vfw movies 7/18/2008 12:38:29 AM
destroy quicktime movies 7/18/2008 12:38:29 AM
deinit and destroy capture devices 7/18/2008 12:38:29 AM
destroy dibs for pictures 7/18/2008 12:38:29 AM
destroy pictures 7/18/2008 12:38:29 AM
destroy more surfaces 7/18/2008 12:38:29 AM
destroy system surfaces if needed 7/18/2008 12:38:29 AM
destroy system preview surfaces if needed 7/18/2008 12:38:29 AM
destroy overlaysurface if needed 7/18/2008 12:38:29 AM
stop vidnet if running 7/18/2008 12:38:29 AM
--------------end finalize-------------- 7/18/2008 12:38:29 AM
destroy screens 7/18/2008 12:38:29 AM
create screens 7/18/2008 12:38:29 AM
search main dxdraw 7/18/2008 12:38:29 AM
set dxdraw resolumedraw 7/18/2008 12:38:29 AM
position mainscreen 7/18/2008 12:38:29 AM
check for dvdmax 7/18/2008 12:38:30 AM
set global settings for multi and single screen 7/18/2008 12:38:30 AM
initialize all screens 7/18/2008 12:38:30 AM
dualscreen is false 7/18/2008 12:38:30 AM
initialize dxdraw 7/18/2008 12:38:30 AM
--------------begin intialize-------------- 7/18/2008 12:38:30 AM
creating overlay if needed 7/18/2008 12:38:30 AM
create surfaces 7/18/2008 12:38:30 AM
width:320height:240 7/18/2008 12:38:30 AM
create vidnet object 7/18/2008 12:38:30 AM
create spectrum surfaces 7/18/2008 12:38:30 AM
create watermark surface 7/18/2008 12:38:30 AM
create system surfaces 7/18/2008 12:38:30 AM
create system preview surfaces 7/18/2008 12:38:30 AM
create directshow movies 7/18/2008 12:38:30 AM
create vfw movies 7/18/2008 12:38:30 AM
check quicktime and create movies 7/18/2008 12:38:30 AM
check for capture devices 7/18/2008 12:38:30 AM
create dibs for pictures 7/18/2008 12:38:30 AM
create picture objects 7/18/2008 12:38:30 AM
create picture dib objects 7/18/2008 12:38:30 AM
create plugins 7/18/2008 12:38:30 AM
create flash 7/18/2008 12:38:30 AM
again try dvdmax if not created and if supported 7/18/2008 12:38:30 AM
get bltcaps 7/18/2008 12:38:30 AM
--------------end intialize-------------- 7/18/2008 12:38:30 AM
assign additional screens to resolumedraw engine 7/18/2008 12:38:30 AM
position displays 7/18/2008 12:38:30 AM
set screen setups 7/18/2008 12:38:30 AM
start render engine 7/18/2008 12:38:30 AM
render engine started 7/18/2008 12:38:30 AM
