here is my configuration
core2 duo t5550
3gig ram
120 gig 8MO 7200T
nividia 8600m GT
when i try to start resolume 2.41 or 2.3 or 2.4 it freez on the logo!!! and nothing else
first time i see that with reolume!!!!
thanks for your help
here is the log file
Logging started: mardi, 05 août 2008 - 19:23
start up 05/08/2008 19:23:16
create my documents folder if not exists for current user 05/08/2008 19:23:16
create application data folder if not exists 05/08/2008 19:23:16
check direct x version 05/08/2008 19:23:16
check if flash is installed and version 05/08/2008 19:23:16
init: previewer 05/08/2008 19:23:19
init: decks 05/08/2008 19:23:19
init: file browser 05/08/2008 19:23:19
init: fx 05/08/2008 19:23:19
init: sources 05/08/2008 19:23:19
init: preferences 05/08/2008 19:23:19
load avaliable MidiInput devices 05/08/2008 19:23:19
Init Midi Controller list 05/08/2008 19:23:19
Init Midi Notes list 05/08/2008 19:23:19
Init Key list 05/08/2008 19:23:19
Init Audio Capture device list 05/08/2008 19:23:19
Load settings 05/08/2008 19:23:19
Set Midi Input devices 05/08/2008 19:23:20
Init DMX 05/08/2008 19:23:20
Save settings 05/08/2008 19:23:20
gather preferences 05/08/2008 19:23:20
gather channel keyboard shortcuts 05/08/2008 19:23:20
save preferences and keyboard shortcut settings 05/08/2008 19:23:20
gather midi shortcut settings 05/08/2008 19:23:20
get midi channel/ layer shortcuts 05/08/2008 19:23:20
copy midi channel/ layer shortcuts 05/08/2008 19:23:20
copy midi controller shortcuts 05/08/2008 19:23:20
get midi effect shortcuts 05/08/2008 19:23:20
get midi channels 05/08/2008 19:23:20
save midi shortcut settings 05/08/2008 19:23:20
save dmx settings 05/08/2008 19:23:21
init: shortcuts and midi 05/08/2008 19:23:21
init: recording 05/08/2008 19:23:21
init: audio fft 05/08/2008 19:23:21
resolume didn't start!!
Re: resolume didn't start!!
is the display colour quality for your second output set to 16 bit ?
the second display is not activate yet!!
i just want the program to start for the moment!!?,
thanks
c
thanks
c
please need helppppppppppppp!!!!!!!!!!!!!!!!!!!!!!
