Hello,
I've been using Resolume 2 for a long time now with great success. I render my clips in a mjpeg compression designed by matrox at 720x480. It works very swiftly.
But, when i drag my clips into Resolume 3, they don't adhere to the composition. Is the codec not supported in the new version of Resolume? I have 17,000 clips collected over the years in that codec.
When I drag a clip in that codec that has audio, it takes the audio yet not the video.
*shrugs*
-Jon
www.avclubvisuals.com
www.myspace.com/avclubvisuals
