Batch import tool
VJzoo
Batch import tool
Post by VJzoo »
it would be awsome if there was a batch import tool of some kind.
maybe so you could have a folder with subfolder with clips in them and the top level folder is the compation name and then each sub folder is a dec name, and maybe being able to specify colum and layer amounts.
oh and an option to change the paths of clips in decs if you change computors.
not sure how hard it would be to make now that the comp & dec files are all .xml
i cant code but someone else might like to have a crack at it :)
Jas
(the dyslexic VJzoo)
http://vjzoo.com
~ quite nice visuals ~
