I'm currently running a system with two Nvidia 8800GT graphic cards (in non SLI config). Now the problem is that I can only get the output on one card at a time.
When I go into advanced settings I can get see both cards at the same time, but once it's closed it doesn't work anymore.
I have followed the instructions to change the settings, but that changes nothing.
Also the resolution on of one the cards needs to be 1280*960 and the other is 640*480, so is it possible to output at does resolutions simultaneously.
Thanks,
Silvio
Issues with dual Nvidia graphic card
Re: Issues with dual Nvidia graphic card
Hi SIlvo,
When you are in Advanced settings, can you enable the different cards or doesn't that work?
Your cards can run on different resolutions, what you have to do though is select which part of your composition goes where, and that's what the advanced screensetup is for.
The current downloadable version has issues with NVIDIA cards, but we allready made some progress on it but we are still working on it.
