Keyboard & MIDI mapping Problems
bodhiflip
Post by bodhiflip »
I'm having some problems with key mapping in the new Avenue rev1110 that were not there in rev990.
Firstly, the backwards and forwards keys (<, .>) are now not mapped when the clip doesn't have audio. When audio is applied to the clip, the < > keys correctly send the audio / video backwards and forwards. But when no audio is applied and the clip is video only, the < > keys are unmapped and have to be mapped manually by going to direct midi mapping.
Unfortunately, when I try to do go to keyboard mapping in my Windows XP OS on my laptop (clean install only used for Resolume), Resolume crashes (disappears and goes back to Windows Desktop). So I've been unable to use Resolume with Windows XP on my laptop, but strangely it is not crashing when Key mapping on Windows XP on my PC, so not sure where this problem is coming from.
I have been able to go to Midi Mapping when using Resolume on My Vista OS on the same laptop, which is not ideal but is getting me by for now.
Any idea whats going on and when this will be fixed?
