No output to second monitor on Nvidia
oddmachine
Post by oddmachine »
I'm running Windows XP and a Nvidia Quadro 2500m video card. The second screen simply shows a frozen video image. I can't seem to find any way to adjust. The same image occurs when I run in a window on the first monitor.
Also, I found the forum posts about changing the 3d settings, and tried to update drivers, but the 2500 seems to have a different control panel, and I can't find an equivalent adjustment so no success.
Trying to make a rapid decision between this and Grand VJ, though I'm currently running Pilgrim for all my shows and will miss it dearly.
Any help would be much appreciated!
Thanks, Nick
GeeEs
Re: No output to second monitor on Nvidia
Post by GeeEs »
A lot was written about this issue ;)
CHECK
oddmachine
Thanks, I had read that thread. What I was missing was that the stock Nvidia driver from Dell (I'm running a Precision 90 with a Nvidia Quadro 2500m) was completely obsolete.
It needed to be replaced with http://support.dell.com/support/downloa ... id=&impid=
Now I can see the "Nvidia Control Panel" which is referenced in the solution so I'll give it a shot.
Enthused to get this up and running!
-Nick
oddmachine
Works perfectly! I'm amazed at Resolume again!
-Nick
