Avenue blurry??
Suade
Avenue blurry??
Post by Suade »
Hello,
I'm in the unusual situation of wanting pixel accurate output from resolume as I'm using a large, low-resolution Martin LED video wall. This display is only 100 x 50 pixels but needs those to be sent as a section of a 1024 x 768 video signal so I set my composition to 1024 x 768. I've set the video wall so that it displays from the exact centre of the 1024 x 768 image and placing a 100 x 50 animation into Avenue and playing back with no scaling or effects does position the picture correctly. Unfortunately the colours bleed by a single pixel so that a single pixel vertical line ends up 2 pixels wide with one much darker than the other.
I've tried placing the 100 x 50 clip into the 1024 x 768 space offline in an editor creating a 1024 x 768 clip with lots of black around the edges but Avenue still blurs that by a single pixel. Strangely enough the 1024 x 768 clip doesn't blur with Resolume 2.41.
Is there a way I can turn off the pixel blurring and get Avenue to output the RGB pixel values completely accurately? My pixels are 4 cm wide so it makes quite a difference.
Suade
cat
Re: Avenue blurry??
Post by cat »
This is to do with texels not being drawn a from the centre you need to shift the position of the image by 1/1024 left or right, I dont know whether you can do this degree of accuracy in avenue, you could do it in a plugin though I imagine, failing that you need them to add a check box for texel centring.
